A4 problem.....
Fuel Trim: Bank 1 system too lean
Mass airflow sensor: Signal too low
Now, I dont beleive these codes have anything to do with my first issue. I would assume the lean code is from a vac leak? And the MAF code might be from the maf coming unplugged...because as soon as I cleared the code it was right back again. When I T28'd her...I put in a brand new MAF...so I dont think it **** itself that quickly.
When I got home I gave it some gas while in neutral...RPM's go up until Im at 0 boost....then "shudder....glug-glug-glug". The IC to throttle body hose is still attached...but I'll have to wait to see the others. Ideas?
Cheers,
Joel
Unless that substitute value comes not from the Dahlback but from the stock programming (if it's retained in some form) that doesn't compensate for the T28 air, resulting in lean condition.
I'm just thinking aloud here.
