A4 speaker line voltages?
Guest
Posts: n/a
I want to replace the 6" woofers on the rear deck of my 2000 A4 with the symphony system. I noticed that the factory speakers are self amplified so, obviosly, I will need to add my own amp. Does anybody know the signaling voltage of the signal that comes from the head unit? Most amps won't take more than a 3V input, some as much as 10, but I heard that the A4 uses 14 volts for signalling, which I'm having a little trouble believing. If it is that high is there a device I can use to lower the voltage?
I should point out that I'm not looking for ultimate bass here, I just want to fill out the bottom end a bit. I would prefer email in case I forget to check the forum (very busy right now).
Guest
Posts: n/a
amps take alot more than 3 volts.....
I was pushing almost 20 volts thru my amps using an aftermarket DAC... most headunits push 4v clean now... I dont know the answer to your question but i doubt seriously Audi is pushing 14 volts...to get 14 volts of clean power is very difficult and expensive. i would imagine audi is giving around 4 volts out of the deck...
Im not sure if u tapped the right wire, 14 volts would be possible for power from the battery but even that is normally around 13 factory... anything higher involves aftermarket electrical upgrades...
Darren
Darren
iVTEC Yo(ex-B5er)
02-07-2005 04:24 PM
Monster1pt8TQ
05-22-2001 11:17 PM
