ABS Control Module
The dealer (or a well equiped independent) can test the ABS controller ... there is a procedure outlined in the Bentley's. Here's an excerpt from the procedure for the cluter illumination (sounds like your DTC to me)
J104 is the ABS controller
<begin clip>
If ABS warning light does not come on, check voltage of electrical system and test wiring from terminal 32 of ABS control module -J104- to instrument cluster for short circuit to Ground (GND).
- The ABS warning lamp does not switch off after 2 seconds. The red "brake system malfunction" symbol lights up after 2 seconds. Check wire from terminal 32 of ABS control module -J104- to instrument cluster for short circuit to B+ and open circuit.
- Are both the vehicle voltage and the wiring from terminal 32 of ABS control module -J104- to the instrument cluster OK? Malfunction in instrument cluster. <end clip>
Marc
