ABS problems?
Old Feb 10, 2003 | 04:17 AM
fussball.biturbo's Avatar
Default ABS problems?
It feels like my ABS has been kicking in at unnecessary times, like light braking for a stop light, or if i even tap the brakes while turning into a parking spot. at least, it feels like the ABS (so I am assuming it is) I get this intemittent pulsing in the brake pedal, but it is much slower than when the ABS kicks in full force.. does anyone have any idea whats going on, or what I'm talking about
tia
Old Feb 10, 2003 | 04:23 AM
debadged2.8's Avatar
Junior Member
Default Re: ABS problems?
I had the exact same problem. It turned out to be the ABS sensor.
Old Feb 10, 2003 | 04:24 AM
quattrofrog's Avatar
Senior Member
I dunno, but I've heard that one cause could be a poor grounding... Search on that maybe??? I dunno
Old Feb 10, 2003 | 04:25 AM
Senior Member
-that makes sense, if a wheel rotation sensor is dead, then yea that could cause it, good show -Phil
Old Feb 10, 2003 | 04:29 AM
Junior Member
Untill I got the sensor replaced i just pulled the ABS fuse
Old Feb 10, 2003 | 04:35 AM
Default thats what I assumed it was...
but I figured I should ask the collective intellect of the board... anyone know how to see if the sensor is good or not?
Old Feb 10, 2003 | 06:51 AM
saakey's Avatar
Default can i ask, do you also get a clunking sound that comes from the front brakes area?
I get that...not so much in the pedals though, but up front in the brakes...like a fast cluck, cluck, cluck...and under light braking.
Old Feb 10, 2003 | 06:52 AM
QuiksilverS4's Avatar
Default I had the same problem caused by dirty ABS sensors.
My mechanic just pulled them out and wiped the crap off and it was fixed. It could also be a bad ABS sensor.
Old Feb 10, 2003 | 08:20 AM
Matt H. (Silroan)'s Avatar
Member
Were they covered in metalic shavings?
Old Feb 10, 2003 | 08:54 AM
occasionally, but it goes through the pedal also...
popdemonic
Audi Original "S" Cars
May 23, 2006 07:35 AM
pasty
Dec 7, 2005 01:30 PM
jbachert
Aug 7, 2004 10:54 AM
Seanism (clone510)
Jun 2, 2004 08:49 AM
atrak
Oct 15, 2002 03:45 PM
