ABS Speed Sensor Removal
Old Mar 13, 2011 | 05:59 AM
  #11
d3br34k5's Avatar
I tried to remove my passenger side rear wheel speed sensor while replacing a bad wheel bearing. Car is a 2001.5 A4 1.8T. I'm pretty sure this was the first time someone attempted to remove the sensor as it was completely corroded into place.
While trying to tap around its edges to loosen it up, I managed to crack the cast housing of the sensor. After doing that I decided to just try and muscle it out with some vice grips since I would be replacing it anyways and it sheared off, flush with the hub. Man was that copper sheath ever stuck in there with rust.
Got the upright off the car and hammered the broken sensor out with a drift pin, following that with a good emery cleaning of the hole.
In retrospect, I should have just disconnected the connector at the module under the back seat and not messed around with trying to get that sensor out at all.
When reinstalling your sensor, make sure to use some never-seize or equivelant on both the little bolt and around the sensor itself, though the replacement ones are usually sheathed in plastic now.
vtraudt
Jun 29, 2014 05:36 AM
BinsuJiro
Audi 100 / A6 (C4 Platform)
Apr 7, 2008 02:52 PM
PKmode
Mar 15, 2008 02:39 PM
Hibiscus Red S4
Aug 15, 2006 04:26 PM
~DonQPremiumTequila~
Oct 12, 2005 11:08 AM
