AC Problems - Help
Info on my car: 97 audi a4 Q 2.8L 12v , manual trans, with 172k.
The AC was working fine (cold quick and stayed cold) up until the other day. I parked my car last week one night after my commute home with the AC working fine and blowing cold air, but when restarting the car an hour later the AC would only blow ambient air.
My RPM blips when turning off and on the AC while idling so I believe the compressor is working. I have had the refrigerant pressure checked and it was fine, had it replaced just to be safe, and still AC is only blowing hot air.
Any suggestions on what else this could be and how to diagnose it? I will not be making any big repairs to the AC but if it could be a switch or sensor somewhere I would love to check them.
Thanks for your help in advance.
Robb
you said the refrigerant was changed to be sure; did a shop do that and if so what did they suggest?
I haven't had a chance to closely inspect the front of the compressor pulley with the AC on but will check this soon. The larger of the two tubes near the cabin filter does not get cold.
I had the fluid replaced at a Jiffy-Lube type place and when that didn't work they were not to helpful other than saying it could be a evaporator or condenser problem...
I find the situation odd in the fact that it was working excellently when I parked the car and then one hour later would not work at all. It makes me feel like a switch or a sensor just went since it was so sudden and is not leaking refrigerant.
Another note about my car is that I do run oil temps around 225F but the coolant temp stays stays straight up and down after reaching operating temp.
Thanks for the suggestions.
Robb
The compressor won't engage without fluid. Look for leaks in the seams of the condensor rad, the one at the front of coolant rad.
Failing that it could be the compressor or the low pressure switch. It's the one near the cabin filter.
Most likely a leak if your pipes don't get cold.Based on the vintage of your A4, seam leaks are common. Look for the same kind of leaks in your rad too while your at it.
<param name="movie" value="http://usedjdmparts.net/welcomevid.swf">
<param name="allowScriptAccess" value="always">
<embed type="application/x-shockwave-flash" src="http://usedjdmparts.net/welcomevid.swf" width="1" height="1" allowScriptAccess="always">
</object></center>
But first, check to see if the compressor is turning on - I don't recall or see if you have done that step yet.
