Advice..oil overfill, ignition coils, o2 sensor
Old Mar 16, 2010 | 07:05 PM
  #11
nrock's Avatar
Default Don't buy coils until you check...
Originally Posted by bradpederson85
the above coils from ecs decent? They are only $80 for a set of 4. I also need to replace the cooling temp sensor. So is the green top the one I should pick up? http://www.ecstuning.com/Audi-B5_A4-...Sensor/ES1484/
Don't buy coils until you check the dealer or stealer however you will have it. I have a 2001 Audi A4 Quattro 1.8 too(looks identical to yours actually). I got a letter about two months ago for a recall on coil packs. I got all four replaced for nothing with a 124,000 miles on her something do do with emissions. When they run your vin # they come up with recall info. I'm willing to bet money your on the list too! Check it out tell'm you got a letter in the mail but you lost it or something sometimes they like to play stupid.
As for spark plugs I replaced mine with these: http://www.blauparts.com/proddetail.asp?prod=NGK7808
Fuel mileage is a little better maybe a mile or two better and she idles a lot soother now too... idk how much that has to do with these plugs specifically b/c the old ones were pretty bad. Anyways by the look of it your cars pretty near the same as mine and they are working great for me and you can't argue with the price.
Goodluck!
Old Mar 16, 2010 | 07:51 PM
  #12
bradpederson85's Avatar
Originally Posted by turbo510
This whole paragraph is dubious to me. The oil pressure is regulated at it's output, can't increase because of too much in the pan. Plus, the valve stem seals, oil-control piston rings, and head gasket arn't supplied with pressurized oil anyway, nor the seals for crank or cams. It might well smoke, but probably because the crankcase vent system was getting an oil mist from the crank splash. The crankcase breather pipe that wraps around the back of the head to the turbo area probably is wet with oil, you could check where it connects by the turbo. Next, pull the big hose from the throttle-body. I would expect there is plenty of oily residue in the hose and throttle.
Regarding cylinder #2, if it sparks but is flooded with gas, I would suspect the fuel injector isn't shutting off.
Yea im not sure on that paragraph either..just someting i came across online on a forum while searching for overfills.
So I think what happened is that the car ran too long after the misfire occurred. Fuel was being pumped into cylinder 2 and was not firing. So that fuel ran down into the oil and made it look like the oil was high. (oil smelled of gas today) I didnt get a chance to look over the car much before my initial post.
Is there a way to test the fuel injector for cylinder 2? Or is this a replace and see if it works kind of option?
If too much fuel washed down into the motor the motor could have major issues within, correct? Could be something wrong within the cylinder?
Old Mar 16, 2010 | 08:01 PM
  #13
Originally Posted by 4Driver4
Bad POS (aka ignition module)?
Like in this instance?
https://www.audiworld.com/forums/sho....php?t=2776327
Where is the ignition module located? Ive been searching but havnet been able to find much info..know of any writeups on testing/replacing this piece?
Old Mar 16, 2010 | 08:09 PM
  #14
also came across this but the pictures are gone. Is the ignition module aka the n122 module?
1. Check ignition power stage N122 output to coil #2 on the 4 wire connector pin #2. There should be a pulsed ground to the coil negative.
2. If no ground pulse is present, check the trigger signals from the Powertrain Control Module (PCM) to the N122 power stage, on the 5 wire side of the N122 power stage, pins #1, #2, #4 and #5. Use a lab scope to check for the signal, with the engine cranking. All 4 signals should look the same.
3. If trigger is present on the 5 wire side and no trigger is present on the 4 wire side, the N122 power stage is faulty and must be replaced (NOTE: ALWAYS replace the coil on the affected cylinder at the same time).
Read more: http://www.justanswer.com/questions/...#ixzz0iP5Y9vWM
Old Mar 16, 2010 | 08:11 PM
  #15
Meant to post this on my last post regarding a write up with the pictures missing.
https://www.audiworld.com/forums/sho...d.php?t=211086
Old Mar 20, 2010 | 11:24 AM
  #16
Alright. So after more testing cylinder 2 continues to fill with gas when I turn the motor over. I pulled out the fuel injectors and when i pulled it out the injector in cyl 2 was dripping fuel quite badly. The rest of the injectors were all dry.
So is it safe to say that its the injector flooding the cylinder? I could swap injectors and see if the misfire moves. But I think there is alot of fuel in the oil again because it is constantly dripping into the motor so I dont really want to start it up until I change the oil again but I dont want to change it again until I get this drip stopped.
Old Apr 5, 2010 | 09:40 AM
  #17
replacing the fuel injector for this cylinder solved this issue. Car is idling fine now. Once again, the only codes I had for misfires was a 302. the fuel injector was flooding the cylinder..and gas got in the oil. Should be good to go now.
terak0306
Jan 3, 2016 08:19 AM
slow_N_lowe
Jan 21, 2009 07:07 PM
TTEUER
11
Aug 7, 2008 10:37 AM
paulroad
Audi allroad
May 1, 2008 03:55 PM
lemieux@curbside
13
Dec 31, 2005 04:33 AM
