aight so compiling the list of crap to replace. tell me if I forgot anything
the car has 170k. motor will be built.
N75 valve
coolant temp sensor
clutch (South Bend stg 5)/bleed
Motor Mounts (RS4)
Trans Mount (Allroad)
Smog Pump (gotta check it)
Valve cover gasket/cam seals/tensioner (when motor gets built)
Coil Pack boots
BPV (710N)
vac lines (doing today)
coolant flush
rebuild calipers
Brake fluid flush
shifter linkage (going all JHM)
fuel filter/fuel pump (044)/ sender
pollen filter
control arms/TRE (need to inspect)
alignment (after suspension install)
N75 valve
coolant temp sensor
Motor Mounts (RS4)
Coil Pack boots
BPV (710N)
coolant flush
rebuild calipers
Brake fluid flush
pollen filter
