Alignment problems...
The car is pulling to the right (again) as it did before I replaced the CAs and TREs.
What in the world would make the alignment go out again? I certainly did not hit anything or really stress the suspension since last week.
I've got another appointment with the dealer to see if they can fix it again... yay...
Then, if it is still pulling, get the alignment redone. Make sure when you are pullingthe tires you check the tie rod ends. They may have left an adjuster loose.
If the dealer has it, ask them to double-check your CA & TRE work.
