Alignment Question...
Old Apr 18, 2005 | 06:28 AM
co859's Avatar
Default Alignment Question...
New wheels about to go on...First Tie Rod Ends are being replaced. should I have my shop do the alignment with the stock wheels that are on it right now? Or should I wait and put my new wheels on first, then get the alignment done?
Also, I was told the tires in the front of the car wear faster than the rears. Sounds true, any comments? Rotate every 5k...
And Finally....Does anyone have a Diverter Valve for sale? I still have my stock one and its MUST be in poor condition since I chipped and the car has 80K on it....
Old Apr 18, 2005 | 07:21 AM
Silver Streakin''s Avatar
Member
Default You should have alignments done with your summer setup on. rotate at 5k oil changes. OEM BPV is fine
because it's a rubber diaphram. it's not going to wear out - it's just going to break/pop. once it breaks, then replace it with a 710N (225hp TT BPV that you can get from your dealer for $30). people say to change out the OEM one because it's not rated for 15psi+ of boost and you get a quicker throttle response with the metal piston type BPVs like Bailey or Forge.
As much as I like the lifetime warranty with my Bailey, I'm on my 3rd one.
Old Apr 18, 2005 | 11:45 AM
co859's Avatar
Default Re: You should have alignments done with your summer setup on. rotate at 5k oil changes. OEM BPV is
Couldn't I be leaking boost if my stock DV is leaking? how much better is the aftermarket ones?
Old Apr 18, 2005 | 08:55 PM
Member
re-read my prior post. search if that doesn't answer it for you.
GDawgA4
14
Mar 24, 2007 03:39 PM
MikeReno13
16
Jan 25, 2007 12:39 PM
All Z Time
Jun 28, 2004 07:21 PM
gragravar
Audi allroad
Apr 22, 2004 09:48 AM
fez
Nov 10, 2000 08:47 AM
