Alignment, or steering box?
Old Nov 29, 2005 | 07:26 AM
MDMac's Avatar
New Member
Default Alignment, or steering box?
My 1995 A4 has recently started pulling to the left......is this alignment, or could it be wearing in the steering box? How would you tell if there was wear in the steering box?
MDM
Old Nov 29, 2005 | 07:31 AM
4Driver4's Avatar
Tech Guru
Tech Guru
Default Tires?
Start by checking pressures all the way around. Look for abnormal tire wear. If none, swap tires front to back. If you have abnormal wear, something is worn out or bent in the front end.
Steering rack should not be a factor.
tobin's Avatar
Default Alignment
It could be many different things. Check all your tires' pressure and tread first. If that doesnt help, get a four wheel alignment at a reputable shop. If that doesn't fix it, check back with us.
Old Nov 29, 2005 | 07:34 AM
MDMac's Avatar
New Member
Default Re: Tires?
Cheers,
What would be signs of problems with the steering rack?
MDM
Old Nov 29, 2005 | 07:35 AM
MDMac's Avatar
New Member
Default Re: Alignment
Thanks,
I'll check for uneven wear now, if I can, its starting to get dark quite early now on this side of the pond!
MDM
Old Nov 29, 2005 | 08:05 AM
shwndh's Avatar
A 95 A4? I thought 96 was the first year of the A4. Check your tire wear.
Old Nov 29, 2005 | 08:07 AM
4Driver4's Avatar
Tech Guru
Tech Guru
Binding when you turn the wheel, fluid leakage, or power assist problems, mainly.
barberan
Audi A5 / S5 / RS5 (B9)
15
Sep 16, 2017 08:05 AM
dpdonahue
A7
Oct 12, 2016 06:00 PM
uTTdriver
May 25, 2004 08:26 AM
Philip W
Jan 16, 2003 06:55 PM
S4_4MY30'S
9
Nov 2, 2001 12:32 PM
