Any way to find the ignition, illumination, and constant wires if your stock radio harness is gone??
tried the audio forum already... wires have been cut up from previous installs no more stock harness...
i have my radio area pretty accessible due to partial carpc install I can take some pictures
you might be able to match up color codes and such. I know the power/ground are just a bit larger than signal cables. Only issue with taking pictures, I unfortunately have Bose. Let me know if you want the pictures or not.
Just noticed you wanted only power/illumination... so those should be the same Bose and regular.
pictures would be a huge help if its not too much trouble.. there are just so many wires everywhere
at this point I dont know where to start and I dont have a volt meter... I once I can find the Ignition (most important) the power and the illumination the rest shouldn't be too hard
picture of power/switch/illumination
<center><img src="http://pictureposter.audiworld.com/88525/dsc_6183.jpg"></center><p>this picture from closest row from left to right: switched, illumination, ground
the wire right above ground (brown) is constant 12v (red, blue stripe)
see the link for more description.<ul><li><a href="https://www.audiworld.com/tech/elec164.shtml">https://www.audiworld.com/tech/elec164.shtml</a</li></ul>
99SilverA4
05-25-2005 02:54 PM
quattro90S6
06-18-2003 03:59 PM
