Anyone needing to touch up chips? I used the Audi spray touch up paint with great success.
I have used it as a spray paint with excellent results but this time I sprayed it into a cap and used a fine brush to do touch ups. Worked great. It is thin enough so you can build up the layers. Dries fast enough so you can finish in one go(careful it does not dry on your brush).Load the brush and touch the spot so it can wick into the chip/scratch. Repeat as nec. Be sure to clean the spot first,I used BetaClean. The match was perfect.
Picture of my grille sprayed with the paint so you can see the match.
<IMG SRC="http://pictureposter.audiworld.com/8297/frontlow.jpg">
I'd show you the chips,but you couldn't tell from the photos. It's that good of a match.
Projekt 8E
05-05-2003 09:38 AM
