audi a4 fuel pump housing
No it should be fixed or stationary. I had a 1998 A6 that went off the road, hit a rock right under the fuel tank and broke the part that held the fuel pick up to the bottom of the tank. No visual clue on the outside of the fuel tank, no scratches or leaks. But the fuel pick up was then able to float up in the tank and suck air when there was still a half tank of fuel. Had to pull the pump and pick up out of the tank and replace the piece that held it to the bottom of the tank.
Sorry, no photos. I had to replace the bracket, not the pump. Can’t imagine glue working in a fuel tank. If you search the Audi parts houses you will likely find diagrams of the components inside the tank. You probably want to open the tank covers and look around before ordering parts. Carefully...
tjmccabe
Q7 MK 1 Discussion
01-15-2017 06:51 PM
turbogoat
Audi 100 / A6 (C4 Platform)
02-13-2015 08:01 PM
Tofu4679
11-10-2011 07:34 PM
