B&M Short Shifter
Old Feb 11, 2004 | 06:09 AM
SGH's Avatar
SGH
Default B&M Short Shifter
Does anyone have experience with the B&M short shifter? I am looking at that and UCC, any experienced comments would be helpful.
Old Feb 11, 2004 | 06:35 AM
DC Dawg (Married)'s Avatar
Default I hear good things but start here ther have been lots of SS reviews
<ul><li><a href="http://search.audiworld.com/index.mhtml?q=Short%20Shifter%">http://search.audiworld.com/index.mhtml?q=Short%20Shifter%</a</li></ul>
Old Feb 11, 2004 | 06:49 AM
LaR H 88's Avatar
Elder Member
Default eh...its ok
I had a lot of play in mine initially, so i had to disassemble and bend the fork a little bit closer and do the zip tie mod. I'd probably try the v&amp;s or strat before the b&amp;m though.
Old Feb 11, 2004 | 07:02 AM
OSin456's Avatar
Default After installing it I don't see how the other shifters don't have "play" as well
I went straight for the B&amp;M and it wasn't the Snic-snic shift I was some what expecting @ 35% reduction. Rather much like stock, but with a shorter shift, and a bit more effort, and it is in-turn a tighter shift. But from installing it and seeing how the Linkage is the only think that determines where the shifter goes, I don't see how the zip-ties or other shifters could be tighter. There are no gates or anything to tighten up.
That being said I have not tried another, but on the outside they all look the same (more or less) and the link-age is the same, so I dont' see how they can be tighter. So I don't know.
Old Feb 11, 2004 | 07:24 AM
simply J's Avatar
Senior Member
Default i had the b&M... now I have the V&S
the B&amp;M was an improvement over stock but sucks compared the the V&amp;S. Not worth the money at all, they basically designed it so it would be able to be used in several applications and thus compromised quality and feel.
Get the V&amp;S or Strat
Old Feb 11, 2004 | 08:16 AM
LaR H 88's Avatar
Elder Member
Default It's not just the linkage that has play, though
Granted, the linkage probably contributes to most of the play in the shifter system. Although it is the main contributor, that doesn't mean that there aren't ways to significantly reduce it elsewhere. If you try pulling up on your shifter when it is in neutral, does it move a bit? The pivot ball had a lot of play, so tightening the cups down with a zip tie helped immensely. Also, the fork at the bottom of the shifter was fabbed too large for the shifter. There was a decent amount of play there that was amplified further up the shifter. I bent that in a bit and a good chunk of the play went away. I still want to try to replace that linkage parts, but that's going to be a huge pita. Well, this is how I see it - your results may vary.
Old Feb 11, 2004 | 09:24 AM
quattro_silver's Avatar
Default I have play "Left to Right" "Up and Down" when in Neutral with mine.
I am thinking about doing the Zip-Tie MOD, but I have the push-down reverse, so I don't know if I can do the Zip-Tie MOD. I was actually considering replacing the ball/sleeve parts, since I had this slop/play BEFORE installing the B&amp;M.
Old Feb 11, 2004 | 09:59 AM
LaR H 88's Avatar
Elder Member
yeah...seems like the cup is a bit loose. get a new one or if you're cheap, try the zip tie mod
wct
Feb 23, 2008 06:57 PM
1titSantorin
May 21, 2007 07:29 AM
GETTINGBLOWN
16
Sep 21, 2005 10:17 AM
Phoenix33759
Nov 21, 2004 07:51 PM
DeutschDriver
Aug 17, 2004 01:25 PM
