BIG trouble..possibly Timing Belt
Story is that I was driving and all of a sudden the steering gets hard look at my volts and they dropped.. so I knew it was the drive belt..pull off and see that my drive belt tentioner locked up.. So I try to get it home but then my car just stalled.. Couldnt figure it out and I thought it was just the battery going down..I changed the drive belt and tensioner and still wouldnt start.. pop the timing belt cover and the belt isnt moving when I turned the car over.. Devasting..there still feels like there is tension on the belt but no movement. My question is that could the valves be ok even though this happended..I just dont want to get this done and end up having to do the heads too..
NO BELT MOVEMENT
NO BELT MOVEMENT
at this point whether or not it was 30k miles, doesn't fix your bent valve issue. I would have
liked to see proof of when/what was done. I had a 1.8T in a Passat, and 1 mile from my mechanic (to do a timing belt change) the belt broke. It had 186,000mi or so on it..... I was bummed.
