Bleeding radiator
Old Feb 26, 2003 | 03:28 AM
vincenzo's Avatar
New Member
Default Bleeding radiator
Does anyone know where the bleeding screw is on an A4 '96? I was told that it is located under the expansion tank but I couldn't find it. I believe that I have an air pocket in my heater's radiator.
Old Feb 26, 2003 | 04:59 AM
Kris Hansen's Avatar
Head Cat Herder
25 Year Member
Default It is under the expansion tank, it is an allen head, in the metal pipe.
Unscrew the tank, lift it up a little, and look down right between the firewall and the driver's side cyl head.
Also, make sure you bleed out the feed line to the heater core, by sliding it off of the barb a little.
What are your symptoms?
Old Feb 26, 2003 | 05:18 AM
vincenzo's Avatar
New Member
Default Re: It is under the expansion tank, it is an allen head, in the metal pipe.
WHEN I'M ON THE HIGHWAY, THE TEMPERATURE DOESN'T GO ABOVE 65 DEGREES. IN THE CITY, IT COULD GO UP TO 90 BUT AS SOON AS I DRIVE FOR A LONG STRECH, IT FALLS BACK DOWN AT 65 AND THE TEMPERATURE INSIDE THE CAR IS NOT THAT WARM.
Old Feb 26, 2003 | 05:39 AM
Head Cat Herder
25 Year Member
Default Sounds like a bad thremostat to me.. An air pocket would mean no heat in the car (usually)..
and high temps on the guage.
Old Feb 26, 2003 | 05:42 AM
vincenzo's Avatar
New Member
Default Re: Sounds like a bad thremostat to me.. An air pocket would mean no heat in the car (usually)..
I forgot to say this but when accelarate, I hear bubbles in my dash. All this started when I changed my ECT sensor. Before that, everything was OK. Actually, there is very little hot air that comes in the car. Do you think that it could still be the thermostat?
Old Feb 26, 2003 | 06:02 AM
Head Cat Herder
25 Year Member
Could be. Could also be air. Try to bleed it, see how it goes.
Old Feb 26, 2003 | 07:05 AM
vincenzo's Avatar
New Member
Default Re: Could be. Could also be air. Try to bleed it, see how it goes.
THANKS MAN.
qwert1234
Q5/SQ5 MKI (8R) Discussion
14
Feb 12, 2022 12:55 PM
edupin
Oct 1, 2017 11:22 AM
animmo
Nov 23, 2009 07:20 AM
big_anthoiny
Sep 19, 2007 04:17 AM
ScarfaceNostra
Aug 24, 2004 05:25 PM
