Boost Leak Continues...
<img src="http://pictureposter.audiworld.com/45027/boost_spark_plug_2.jpg">
<img src="http://pictureposter.audiworld.com/45027/boost_spark_plug_3.jpg">
Grrr....ARGH.....
I can only really hear it leaving toll booths due to the Walls that are nearby. The sound is able to enter the car at that point...
but i really think it is a vacuum leak and not a boost leak, this is based on your fuel trim. replace all your vacuum hoses.
The simple test I used to determine it was the actuator was to use a hand vaccum pump (MityVac) hooked up to the silicone hose that goes from the N75 to the wastegate actuator. I started pumping teh MityVac and air was just rushing through the actuator (it wouldn't hold vaccum). that convinced me I had foundthe problem. Once my new actuator arrived, I performed the same test, and the new unit would hold vaccum.
Good Luck.
