Brake Bleeding/Flush
Old Jul 27, 2006 | 02:38 PM
alms_lefko's Avatar
Default Brake Bleeding/Flush
Ok, i HAVE searched alot...
Is the power bleeder the best/easiest way to bleed the system once i replace my pads? Is it easy? How do i do it?
Also... thise the same way to flush the system with new fluid?
Old Jul 27, 2006 | 04:13 PM
Ertman's Avatar
Default Motiv Brtake Bleeder - Best $50 that I have spent ....
instructions are included
Old Jul 27, 2006 | 06:38 PM
GPJ's Avatar
GPJ
New Member
Default I use 1/4" clear tubing, and a milk jug.
A deep socket is best to crack open the bleeder. Attach the tube, use gravity bleed to fill the tube a few inches, then pump the brake pedal (no more than 1") until clear fluid is pumped through. Keep your master cylinder filled. That's it - no power bleeder, no one-way check valves.
If you can't gravity bleed a few inches because of clogs, just pump. This will work fine if you are only flushing with no bubbles in the system.
The same method can be used for the clutch slave, but a thumb serves as a check valve, and pump the clutch pedal instead of the brake ;-)
I used about a quart and a pint for the entire flush. I prefer Castrol LMA for the street - it lasts longer than the race fluids that some like to use on the street. LMA is originally "Girling Amber" and is obviously Girling approved, and very easy on all seals.
Old Jul 28, 2006 | 04:02 AM
Mr. Mom's Avatar
AudiWorld Expert
Default Get speedbleeders $7 each...
<ul><li><a href="http://www.speedbleeder.com">http://www.speedbleeder.com</a</li></ul>
Old Jul 28, 2006 | 04:54 AM
tobin's Avatar
2nd, amazing tool and great results
HdiaS4
Jul 22, 2007 12:18 PM
habe Ich gesagt
Audi 100 / A6 (C4 Platform)
9
Apr 27, 2007 08:33 AM
arran
Apr 5, 2004 06:06 PM
maurizio
May 30, 2001 12:43 PM
mxz
Jan 31, 2001 11:05 AM
