Brake lights always on
Hey all,
I have a 96 A4. The issue this car is having is simple, and actually the same thing happened in my Golf.
The brake lights are always on! Bad return spring?
When you actually apply preasure to the brake pedal, the front left turn lamp goes on
Also the there is a chime when the door is open and you push the brakes. Tell me this is simple.Please.
Thanks in advance for the help!
Sounds like you might have a short in the left rear assembly.
Check to see if the parking lights come on too when you hit the brake pedal. This would cause the door chime to come on.<p><a href="http://registry.audiworld.com/audi/registry/details.asp?car=5395"><IMG SRC="http://pictureposter.audiworld.com/audiworldpics/2000/cmhatp0016.jpg" border="0"></a>
Re: Sounds like you might have a short in the left rear assembly.
Thanks for the response!!
Okay so it's possible when I relaced the bulbs in back that I shorted out the assembly. The left parking light up front does come on!
So am I using the wrong bulbs? Or is it possible I would have to replace the entire rear bulb assembly?
audi/s/scott
03-01-2009 01:35 PM
jjguitarranch
01-25-2006 08:47 AM
AUDIA4_TDI
04-15-2004 07:31 AM
Colorado A4
12-24-2000 05:57 AM
