Brake Question (NOT wet-braking)
Hello all,
I was driving down a steep, twisty hill at speeds between 40-60 (limit is around 30-35 I think) (please spare me the flames)... and when I was turning, I applied the brakes a little and felt a grinding sorta feeling under my foot. I had just tapped the brakes and felt this, but nothing else happened afterwards. The turn was kind of sharp (felt the bobbing/weaving w/sport susp.). Just wondering if it was ABS or if it is a brake problem or if it will be potentially. TIA.
Chard
99.5 1.8tqms silver, APR on the way!
Chard
Re: Brake Question (NOT wet-braking)
Did it feel like the ABS? The only reason I ask is that I had a grinding feeling in my old Jeep Grand Cherokee that turned into a horrible grinding sound by the time I could get it fixed (I was away). It turned out to be a major brake overhaul that cost me about $1000. I don't remember exactly, but I think the pads were completely worn out and the result was metal on metal when I applied the brakes. I don't know what exactly your feeling, but if it feels wierd, get it checked out, its worth it.
my $0.02.
Jim B 99.5 2.8qms
my $0.02.
Jim B 99.5 2.8qms
Re: Probly ABS...
I agree with Jake. If it was grinding all the time, then your pads are worn. But if it was a temporary weird feeling of the brake pedal, then the ABS system probably cycled on you during the event.
hman_a4
07-25-2002 01:15 AM
Greg "S" (not Slater)
08-19-1999 08:20 AM
