Bypass wasn't the answer for me...
So recently I had some boost leak amoung with some other problems that provoked me to get a new BPV, so I picked up a TurboXS H25 and installed it 2 days ago, I started off with 4 washers in it, but still heard the hissing as accelerated even more so than the stock, especailly when at low rpm in a higher gear. I tried 3 washers, same thing... so now the question...
Is the hiss I'm hearing cause by the BPV? If so what can I try to fix it? more washers? less washers? or do I just have a small leaking hose?
TIA
Greg
TIA
Greg
Are you sure the hissing is a leak and not just
the spool up and bpv return line you hear out of the new intake tube. The intake tube will make the turbo noise twice as loud then the stock air box.
BTW do you have a boost gauge to see if your are getting the set boost you should be running.
Sloooo4esT
Audi Original "S" Cars
9
08-18-2006 07:59 AM
XcellR8edAudi
04-04-2005 06:07 PM
UberVier
11-03-2003 02:01 PM
Wilder_rocks
09-29-2000 09:17 AM
