Cam Chain Noise - Chain or adjuster/tensioner?
I've got a 01 A4 1.8TQ Tip with 150k mi. It is making a ticking noise at idle and sometimes a grind noise when taking off slowly from a stop. Sound is coming from the rear of the valve cover. It is also throwing code P0011 - "Intake Cam retard setpoint not reached - over advanced - Intermittent".
It sounds to me like it needs a Cam Chain Adjuster (tensioner). Is it possible it is just the chain itself that is bad? I've read a lot about the issue, but never any reference to just changing the chain. Any input is appreciated.
Re: it's not the chain. it's the tensioner, that chain is massive for the job it does...
Hmm. Thats not what I wanted to hear. The chain is like $20, and the adjuster/tensioner is like $400. Other than the timing issue, what are the consequences of letting go for a while? What is actually making the grinding noise?
a comment....
<center><img src="http://i27.tinypic.com/2hd1mie.jpg"></center><p>You might check the oil pressure as well as the stretch in the chain(set to tdc & pull valve cover, etc). At 150k, its probably time for a new tensioner, gasket kit, and chain. Its not a terrible job, but probably not one for the novice.
(pic shows cams & tensioner assembly pulled on a 30v)
well, you are getting tiny parts of metal and teflon into the oil. 911 is right, in that
you might also have an oil pressure problem. I would run some diesel fuel cleaner through the crankcase before you change the tensioner and then change oil. you then may want to do a round of Auto-RX.
Re: well, you are getting tiny parts of metal and teflon into the oil. 911 is right, in that
Clean the crankcase and change the oil as a possible fix? Or just make sure I do that before I change the tensioner?
Thanks
Thanks
VOoDOoGTX
08-17-2007 03:50 AM
AEBlessed (1.8G)
07-26-2007 03:53 PM
mac1964
01-03-2005 09:23 AM
C5867
08-12-2004 06:25 PM
