Cam Sensor?
Cam Sensor?
Well I just got news from the shop that my starting problems were almost 100% from a faulty cam sensor. Anyone able to help me out on what the heck this is and what a normal cost of the part or even part/labor would be? Thanks a ton
Jon
97 A4 1.8T Quattro
Jon
97 A4 1.8T Quattro
What it is: It's an optical type sensor that reads a wheel and tells the ECU where the cam is..
relative to it's rotation. It uses this to adjust spark timing, and fuel injection pulse, among other things I am sure. How much? No idea.
as far as i can determine...
it helps set the injector timing. i can see how this would give you hard starting. i think it's also called a hall sensor, don't quote me on this!! if it is it's $70 here. looks like an easy replace.<ul><li><a href="http://catalog.alloemaudiparts.com/">http://catalog.alloemaudiparts.com/</a</li></ul>
EuroV12
10-17-2013 10:05 AM
shanelu97-Go Eagles!
07-15-2004 05:01 PM
