Camshaft Locking Tool
No need to pop the pulleys unless you are doing work under the cam covers.
Here's a good video.
I think he has done this job before!
You can't be off a tooth. As long as the big holes on the sprocket lobe deals are facing each other and the bar fits on you are timed. Belt position makes no difference.
Do the whole 9 yards as long as you're in there.
Good Luck!
Timing on the 2.8 is infinitely adjustable because the cams are not keyed to the sprockets, thus it is impossible to be "a tooth off".
Free the sprockets. Set the timing. Ignore shortcuts that result in an OK job when you could invest a few more minutes and get a good job.
...and why would you go to all the trouble of doing a belt service yet skip the cam seals?
(Now if I can find one for my 1.8 I'll be set.)
