Can S4 Springs and exhaust go on a 97 A4 Q?
I have a 97 A4 Quattro 5speed, and a set of S4 Springs and exhaust, almost brand new. I would really like to integrate them, but I'm concerned about potential backpressure issues with the exhaust, going from a normally aspirated engine in to a designed-for-turbo exhaust. Also I don't want to spend the 500-1000 my shop is talking about to swap out the suspension if there will be problems. Please help! I'm a new A4 owner, so I'm not sure what the car can handle.
Thanks,<p>-SF BAY, CA-
1997 2.8 Silver/Black Quattro
I dont know about the Exhuast but.. Since you have the 1.8t the springs wont be a good idea
The springs on the S4 are desighned to work with the Extra weight (two turbos , V6) they Might work on the 2.8. Having them on the 1.8 will make the car feel less conected, Understeer. But I dont know about fitting the actual springs ( i dont know if the s4 suspention uses the same lenght/weight Springs. Due to its different front control arms.)
I dont think the exhuast will work either.
Your better off going with a set of euro springs.
And as for the exhaust they are many types, that are made for the A4 turbo.
I know for a fact that the VM1/VM2's fit 30v A4s perfectly... not sure about 12v A4s
<p>- <a href="mailto:adhand@san.rr.com">Anand Dhanda</a>
'00 A4 1.8TQMSx Silver/Onyx
Wett 1 Bar, F/R Fog Mod, Clear Corners,
S4 Grille, Jamex Air Filter, LLTek Shift ****,
Euro Plate "2PE C ME", Westach Boost Gauge
He has a 2.8. There still may be a small balancing issue, but not...
...to the extent of a 1.8. A 1.8 would probably ride high in the front end with S4 springs.<p><img SRC="http://pictureposter.audiworld.com/AudiWorldPics/2000/A4xtsg5.jpg" BORDER=0></a>
2000 Nissan Xterra SE V6 4x4 (personal)
'98 A4 2.8 Q-Tip (business)
p3u
11-28-2005 03:12 PM
Mike Zamarocy
Motorsport Discussion
03-03-1999 06:51 PM
