can someone digest these VAG codes for me? TIA
18010 = low power .. usually from pulling the ECU or the battery
17951=throttle actuator potentiometer signal too low . .check throttle drive and angle sensor
16795= seconadary air injection incorrect flow .. usually a leak in a vac hose
thanks yippers just did a search and found you answered the same questions lol (few ?'s more..)
ok im doin my 40k checkup on monday, so what should i tell them? i know that the 18010 is there because of the GIAC chip. but the 17951 and the 16795? what should i tell them to do?(its not an audi dealer)thanks again =D
Did you try a throttle adaption?
I would clear the codes now and see if either come back. If they do let the dealer 'discover and repair' them. Between now and Monday you should make sure you do 5 or 6 starts from cold to fully warm. That should set all the ready codes.
Many things will set the low power code:leaving a user on long enough to drain the battery and necessitating a jump start; Pulling the power before an extended storage, etc, etc.
Yu_Power
09-23-2004 09:23 AM
nova309
03-06-2003 07:28 AM
JMG
08-19-2000 02:48 PM
