Check Engine Light
Old Jan 27, 2004 | 01:05 PM
zairegp01's Avatar
Default Check Engine Light
I was driving on Friday night and the light came on 5 minutes into a 10 minute drive to Home Depot. I went home and used the car as little as possible. called the dealer on Monday to get an appointment and after asking whether the light was flashing (It is not) the mechanic told me that I had not driven the car enough after the light went on and that i should drive normally for 4 days and call him back if it is still on... Is this normal?
Old Jan 27, 2004 | 01:37 PM
Yippers®'s Avatar
Member
Default The CEL will reset if teh fault isn't serious and doesn't get repeated. Personally, I'd want to know
what the DTC is. Anyone in your area with a VAG tool?<ul><li><a href="http://www.steve-hall.com/cgi-bin/VAG-Locator.pl">http://www.steve-hall.com/cgi-bin/VAG-Locator.pl</a</li></ul>
Old Jan 27, 2004 | 01:39 PM
JAFO's Avatar
Default cold weather can play havoc with the cel...
flashing light meens a serious problem and the car shouldn't be driven. a solid light is less serious and may correct it self. you won't hurt you car by driving with a solid light.
Old Jan 28, 2004 | 05:59 AM
zairegp01's Avatar
Default Re: cold weather can play havoc with the cel...
Thanks - I will see what happens by Friday and if it is still on I will take it in.
phistration
22
Dec 1, 2018 06:26 AM
jackstraw
Feb 11, 2002 03:30 PM
KDL
Sep 13, 2000 08:12 AM
HeavyC
Sep 5, 2000 09:24 PM
LouisE
Mar 16, 2000 08:27 AM
