on cleaning the icv i have read in archives some people use brake cleaner and some i read used wd40.
would you really want to clean your icv with wd40?? i read that it needs to be lubricated..but i thouhght it only neded to be cleaned.. i have read chris hansens write up..
what is an icv? similare to a EGR? exhaust Gas recirculator?
co i know u need to clean you inlet side on vag diesels because of the EGR valve.
You can however use VAGCOM to alter settings so that the EGR valve doesnt work properly thereefore doesnt clog your inlet side with gunk.
bit long all i wanna know is what is an ICV?
I cleaned mine with carb cleaner and then lubed it with some spray
like wd40 or whatever.
it does need lubrication after you use something like carb cleaner which will strip most anything off.
Luxus Panzer
09-14-2006 04:21 PM
mattarios2
11-27-2005 12:58 PM
oddBALL
13
10-15-2003 05:11 AM
