Cold Starting Problems (2.8L V6).....<Long>
Here's the situation:
I started my car a few mornings ago (30F - 40F temps outside) and it went into it's normal high idle at 1,200RPM for about a minute.
When it kicked down to it's normal idle of 800RPM the engine just cut out and died.
Restarted no problem. Started driving to a job site and was going up hill and the engine "hickuped" (stutterd briefly) and the CEL flashed briefly and then it was fine.
Two days ago I started my car in the AM (40F temp) and it did the same thing as previous and just died on me. I tried restarting and it just cranked and cracked. i pumped the gas a few times and it finally started. I drove away and the idle was bouncing around 400-650RPM for a little while until the car warmed up.
Recent DTC's I pulled/cleared with VAG-COM were:
18010 - Power Supply Terminal 30 - Voltage Too Low - Intermittent
17537 - Fuel Trim Bank 2 - System Too Rich - Intermittent
17535 - Fuel Trim Bank 1 - System Too Rich - Intermittent
17549 - Load Calulation Cross Check - Implausible Value - Intermittent
01274 - Air Flow Flap Position Motor - Blocked or No Voltage - Intermittent
01206 - Signal for Duration of Ignition - Off Time - Implausible Signal - Intermittent
00787 - Temperature Sensor in Fresh Air Duct - Open or Short to Plus (NOTE: This one reappeared after Clearing DTC's twice)
Any thoughts on what is going on making my car die out like that?
Thanks.
Thanks.
