Coolant types
Old Jan 23, 2013 | 01:52 PM
Gusset's Avatar
Default Coolant types
My recently purchased 2001 A4 1.8TQ Avant has green coolant. I'm planning to flush the cooling system and heater core soon. Initially I was planning to refill with G12.
However a DIY I recently read for flushing the system recommended re-filling with whatever was there to start with, rather than risk inadvertent mixing of the two different types. This was a bit of a surprise to me. I'd assumed that running the engine up to temp with water and draining again would be sufficient to completely evacuate the system of the existing coolant formula.
How thorough is a flush job at clearing out the old coolant? Maybe it's as simple as doing the water-flush twice.
Old Jan 23, 2013 | 05:10 PM
4Driver4's Avatar
Tech Guru
Tech Guru
I'd run the Audi blue stuff. A flush never gets everything.
Old Jan 24, 2013 | 07:20 AM
tommyleea's Avatar
Take a look at a previous thread from Blauparts..Coolant and timing kits. Some good info.
Old Jan 24, 2013 | 11:09 AM
ECS Tuning-Audi's Avatar
Audiworld Basic Sponsor
I've had good experiences with DEI Radiator Relief Flush. It's very simple to use too. Simply drain your old coolant, close drain, add this to your reservoir then add water. Once your cooling system is refilled with water and DEI Radiator Relief Flush, run the vehicle with the heat on for 15 minutes. Once you've completed 15 minutes drain everything and refill with G13 coolant (new industry standard coolant for all VW/Audi vehicles)
Click HERE to order or for more information.
Let me know if you have any questions.
Jason
r1racer
A6 (C7 Platform) Discussion
Jan 13, 2025 01:24 AM
cheesypoof
Jan 4, 2014 12:14 PM
MingsS4
Nov 8, 2009 08:49 AM
Fastfwd
May 7, 2007 05:32 AM
audipride87
Audi 100 / A6 (C4 Platform)
Sep 10, 2005 10:56 AM
