A couple questions regarding alignment
I recently had installed the Audi Sport suspension springs and shocks on my 2001.5 A4 1.8T,Q that had the stock suspension with the 15" wheels. I also upgraded to 16" Modas with 225/50 tires. The shop that did the install said they did an alignment also. My question is, what specs should be used for the alignment? The specs for the stock set-up or for a Sport set-up? Or more simply, are they different or the same? Also, should the headlights need re-aligning? They seem OK but how would I now if alignment would make a difference? Thanks.
Well, the dealer doesn't bother to replace old bolts and nuts each time...
"It's just a recommendation."
Then again, I think they never bothererd checking the alignment in the first place.
screwynewy
11-22-2000 01:41 PM
RodF
Wheels & Tires Discussion
06-10-1999 08:25 AM
