Cranking No Start (No Spark)
I recently bought an Audi A4 with the 1.8T. Has had a cranking no start since I purchased it. I was told that it broke a serpentine belt cause the AC locked up. The previous own had the AC removed and a new belt installed however a P0011 was thrown and then cleared.
Since I purchased I have:
- Replaced Cam Sensor
- Replaced Crank Sensor
- Replaced both ECM Relays
- Cleaned Battery Terminals
- Cleaned ALL Grounds
- Replaced all plugs
- Checked ALL fuses
- Checked Compression
- Checked Timing
- Checked Fuel pressure
- Disconnected battery for 5 minutes
- Unplugged and replugged in every sensor.
- Pulled codes (Recently got P0685)
- Replaced ECU (From an automatic)
I have fuel just no spark I have checked the harness all the way back to the ECU it looked good. The no spark issue is what prompted me to change crank and cam sensor. I did noticed that when cranking there is no output by the MAF sensor however the MAP sensor is working.
I've officially ran out of ideas.
- Checked ALL fuses
- Checked Timing
pulsar1230
TT (Mk2) Discussion
04-04-2021 09:48 AM
alpinab7
Audi Original "S" Cars
10-30-2005 10:27 AM
4000skq
10-17-2005 03:39 PM
