Custom DP
Old Nov 12, 2002 | 10:53 AM
Dr.quattro's Avatar
Default Custom DP
If I were to do this myself....What would I need? Just some 3 inch mandrel tubing, a tube bender (got that), some flanges, some gaskets, a flex joint, a hanger, that's it right? I want to be able to replace the DP with the original cat for smog purposes. I am also thinking about making a fake looking cat shroud.........anything else?
Old Nov 12, 2002 | 10:57 AM
Audi2ptzero's Avatar
Elder Member
Default 3" is not really needed for a dp.
What size is your exhaust setup?
Old Nov 12, 2002 | 10:58 AM
Dr.quattro's Avatar
Neuspeed 2.5"...would 2.5" dp be fine?
Old Nov 12, 2002 | 11:04 AM
Elder Member
Default 2.5 is fine. The stock one is smaller then 2". I think Pictureboy said it was
1.78" ID. I think the main problem is the stock cat. Get that a little bigger and you will get the exhaust to flow better.
Old Nov 12, 2002 | 12:18 PM
Speedy72t's Avatar
Default mandrel tubing? never heard of it. mandrel bending yes but not tubing.
what's the size of the pipe now? don't go larger than what's allready there.
Old Nov 12, 2002 | 12:36 PM
Dr.quattro's Avatar
Default Exactly....
By totally eliminating the stock cat, and using 2.5" pipe instead...there should be a difference right? I guess I will need to drill a hole for the O2 sensor...and again, make a fake shroud that looks like a cat....then if I am caught, it will look stock.
I would need to pull the cat to measure and determine the proper bends in the tubing...should be easy though, no?
Old Nov 12, 2002 | 01:08 PM
Elder Member
Default I am running a 3" to 2.5" race pipe to a stock DP.
Mad a huge difference, but then I am pumping out alot more exhaust since my motor is 2032cc's with a K04. The race pipe made the boost come on a little smoother and where my full boost (18psi) hits is a little higher in the rpms but after that the power comes on much faster. I have noticed now that I do tend to get a 2-3psi spike and I did not get that before.
kinderutz
Audi Original "S" Cars
Jan 13, 2008 10:39 PM
JPCady
Feb 23, 2004 01:30 PM
Ben/A.W.E.
Dec 8, 2001 11:15 AM
BTCC A4
Jul 3, 2001 11:11 AM
jbrhino
Performance and Tuning
19
Dec 7, 2000 12:27 AM
