CV joint boot problem...
Old Aug 2, 2001 | 11:24 AM
PGAudi's Avatar
Member
Default CV joint boot problem...
this is the second time my CV joint boot has broken (torn) in the last six months... is it something i am doing? is this a problem in the older A4's?
thanks in advance.
Old Aug 2, 2001 | 11:40 AM
Kyle Bailey's Avatar
New Member
Default They wear out with time/mileage
Was it the same one both times, or one on each side? One of mine went at 70K and the other at 80K.
Kyle
Old Aug 2, 2001 | 11:58 AM
PGAudi's Avatar
Member
Default well at first...
it was both boots... i replaced them at about 40000 miles. then the drivers side went (recently) and i noticed it because of the junk in my fender well and i heard this noise today while driving... i havnt put that many miles on.. maybe only a couple of thousand... maybe!
Old Aug 2, 2001 | 01:19 PM
av_audi's Avatar
Default You CV joint is going bad...
If you are hearing the noise while taking corneres, the joint is most likely going bad. Boots do get torn on cars and need periodic inspection. If a torn boot is left unattended long enough, the CV joint will suffer the consequences.
Old Aug 2, 2001 | 01:32 PM
PGAudi's Avatar
Member
Default but its not that old...
what can be causing the tear? why so fast? its not miles.. it cant be... i prolly only put 1000 miles on the car... am i driving to hard... no AutoX for me after i replaced them the first time.
Old Aug 2, 2001 | 02:26 PM
av_audi's Avatar
Default It could be road debris that caused the tear....
Once the boot is open, the grease leaks out and dirt gets in, and before you know it, the CV joint starts making noises.
I doubt how hard you drive has anything to do with the boot tearing. My understanding is that either the boot rubber/plastic dries out in time and cracks, or something hits it hard enough to damage it.
Old Aug 3, 2001 | 11:44 AM
New Member
Default Was it installed by a dealer?
There are some aftermarket boots that aren't all that reliable. There are even two piece boots where you screw the two halves together - avoids having to remove axles.
Mine were not dealer installed (non-OEM), but they've held up well so far. One has 40K and the other has 30K miles on it.
Kyle
PS. I don't think it has much to do with your driving style.
Worldwidebeagle
Audi allroad
Oct 17, 2013 12:16 PM
syckklam
15
Mar 28, 2008 03:32 PM
kjcrede
12
May 28, 2007 05:07 PM
EuroDriver
Jun 15, 2005 05:11 PM
a62.7t4ceo
Mar 6, 2005 06:53 AM
