damaged computer box?
Old Dec 9, 2004 | 11:19 PM
carylag's Avatar
New Member
Default damaged computer box?
I have a 97 A4 1.8 T Quattro. One of my spark plugs isn't receiving a signal from the comp. box hence the car is misfiring, I'm actually only running on 3 cylinders now. One mechanic did some tests and concluded that the whole box has to be changed. Before I go and shell out for a new computer I wanted to ask what other possibilites there are for the misfiring. They did a pressure test on all cylinders and it was fine. I tried putting in a stock chip (i have an upgraded one) but still the same. Also tried switching around the coil packs but still the same cylinder not getting a spark. Would appreciate your input.
Old Dec 9, 2004 | 11:47 PM
BoostTed's Avatar
Default A common failure on some models, not sure if the 97's had the same
But on top on the air box is a ignition control module/POS. Its what that controls the coilpacks.
Old Dec 10, 2004 | 05:23 AM
Mat Indukts Lambos's Avatar
Banned
Default BoostTed speaks the truth. We can get you this Ignition module....
for $140 + shipping, and you'd have it early to mid next week, depending on where you live. It's also a very easy DIY install. Call if interested, number's in the sig.
Old Dec 10, 2004 | 07:13 AM
carylag's Avatar
New Member
Default Re: BoostTed speaks the truth. We can get you this Ignition module....
how would i know if this is really the problem though?
smd1973
Feb 5, 2013 04:23 AM
revisiTTed
Oct 20, 2008 09:37 AM
penguin101b
Dec 19, 2005 10:41 AM
pipewerkz
Mar 9, 2005 06:10 PM
