dealer overfilled tranny 4 years ago, or Audi overfilled 6 years ago.(edited)
When I bought my car in 2000, I noticed something strange-WOT would hesitate a little and I'd get a whirring sound, faint but noticable. I took my car into the dealer several times for this, they said it was normal. I began to believe its what I get for buying an automatic.
FFWD to this weekend I'm changing the fluid. I get the car up to temp, open the inspection port and over a quart of fluid gushes out, its all black and thin, lots of gunk in the pan.
**EDIT***On reflection, I had turned off car before opening ports so level might not have been off in the first place.
I get everything cleaned up, get the level PROPERLY set and go for a drive. No more hesitation, no more whirring.
My theory: Level was so high that the torque converter was frothing the fluid , causing the sound and hesitation. Any other opinions?
Torque converter wasn't doing it but the rest of the internals were...
TQ is not in the oil at all but in front of the trans and the oil gets pumped into it. But all the clutches/bands etc are. Very very possible that was your problem. It probably put a lot of strain on the trans with all the air getting in there instead of oil... bummer.
When you say "got it up to temp" I assume you used a Vag-Com to check the trans fluid temp? If so great, if not and you got it hot under driving and pulled the plug then a qt would probably flow out and the increase in comfort/drivability is just the new oil.
Re: 45C
I just remembered, car was off when I pulled the plug, so the level might not have been too far off to begin with. Odd that the sound has gone away, have you ever seen anything like this?
Houston
It's possible my books are inaccurate (bentley), they show 30-45C or up to 50C for warmer climates.
I'll check some other sources, thanks for the feedback.
audiquattroduo
04-21-2008 07:08 PM
Jiffy Lube put motor oil in instead of transmission fluid in coworker's friend's mother-in-law's car
LCP
07-17-2003 05:12 PM
esses
07-07-2003 10:19 PM
bsewall
11-27-2001 05:46 PM
