decreasing boost.. help!
Old Jun 9, 2006 | 10:24 AM
acidrane-teh jeweler's Avatar
Default decreasing boost.. help!
ok im losing boost by the day...literally!
i had an exhuast leak (cat to dp gets disconnected because i scrape a lot). i went to get that fixed and the guy had to take the cat off. when i got the car back it wasnt boosting as much (12-13psi) and right before i got home i went into limp mode. i took it over to WMS and they cleared it. unfortunetly i didnt save the codes(dumb mistake number 1). after clearing it it went back into semi-limp mode (anywhere from 10-13psi). same nite went to a meet and cleared the codes again and didnt save them...again(dumb mustake number 2).
so i took the car to eurotech and had him check it out. the codes he got had somehting to do with the o2 sensor and my maf was giving out wierd numbers. we switched both out and the car ran stronger but still low on boost(12-13). he did a pressure check and no leaks, he also put in a new check valve. nothing helped with the boost.
everytime i fill up with gas i see 10-12 psi untill i drive hard then ill see 12-13psi. over the past week the boost has slowly decreased. right now im only boostign 5-7psi, last nite it was 9-11. it doesnt feel like its in limp mode but the power isnt there also. i dont know if that makes sense to any of you. what can be the problem? is my turbo on its way out?? it all started after fixing the exhaust leak.
vick
Old Jun 9, 2006 | 10:47 AM
nunya's Avatar
vacuum leak or diverter. Check your hoses.
Old Jun 9, 2006 | 11:11 AM
Default checked...no leaks
im also runnign the 710n dv.
Old Jun 9, 2006 | 11:36 AM
WJM's Avatar
WJM
Tech Guru
could be: tranny, clogged cat , or turbo on the way out
Old Jun 9, 2006 | 11:44 AM
Default how could it be the tranny?
please explain. i thought of clogged cat but jose@eurotech said the car would bog down a lot.
Old Jun 9, 2006 | 12:19 PM
WJM's Avatar
WJM
Tech Guru
Default uhhh what do you thinking losing boost is? That is bogging it down...
you'll also see/feel a lot of heat from it.
If the tranny/torque converter is going kaput, it will lower the requested load, and thus you will not generate boost.
If you have a VAG-COM in your area. Go log the following:
MAF -It could just be your BPV (but doubtful based on your description)
Engine load - During a WOT gear pull. You should see it hit 100% or near it, and hold until you let off the throttle
...and check for codes again
Also you may just want to check your wastegate actuator to make sure it is tight
Old Jun 9, 2006 | 12:34 PM
Default ill check into that.
when i said bogigng, i meant it as rough idle and dying out. my vag adaptor shoudl be coming back soon. do you know which number the maf and engine load is?
vick
Old Jun 9, 2006 | 03:22 PM
JettaRedII's Avatar
Make sure you do a throttle body alignment
 Pouria Savadkouei
 Michael S. Palmer
Old Jun 9, 2006 | 03:35 PM
done everytime.
klr6189
Mar 17, 2014 05:52 AM
triad46_2
1.8T Discussion
Oct 11, 2006 12:42 PM
S4runner
Jul 20, 2006 10:07 AM
Steviecef
Sep 27, 2004 09:28 AM
Steviecef
Sep 27, 2004 07:01 AM
