Help, Power loss at WOT, EPC, checked for boost leaks,bpv, etc....LONG
<center><img src="http://pictureposter.audiworld.com/68526/vaclayout.jpg"></center><p>I have a 2000 1.8T with a GIAC chip. Its been running great till the other day. I got on it at highway speed, (80mph) and when the car downshifted and went for boost, it stumbled.
I thought for sure that I had an obvious boost leak so I made the DIY leak checker from the forum and tested. SSHHHHHHHHHH.
I found a broken check valve blowing loud and strong. Thinking I was victorious in my troubleshooting, replaced it, test drove and to my dismay, it died out again.
Just did the leak test again tonight, no leaks. I put a vacuum tester on the BPV and it seems fine too.
I did get multiple misfire and incorrect boost requested DTCs before replacing the check valve. The only VAG fault I get now is a secondary air injector, incorrect flow.
However. When checking with the VAG on the "readiness" button I get an O2 and CAT "failed or incomplete" Does that mean I have a failed CAT or O2 sensor or does it mean that since I don't have the full version that I can't read it?
I have changed the plugs as well. The car misfires and bucks with both sets of plugs.
What else could it be? MAF? Coil Pack? ICM? Who has been trough this same situation? Thanks much.
where can I get MAF and O2 cheap? Stealership quoted me $246 for the maf alone...
the problem came before the plug change, i was hoping that a regular interval plug change might clear it up as well
ECS Tuning-Audi
A4 (B8 Platform) Discussion
21
09-11-2021 04:04 PM
PoisonBeef
09-04-2015 05:29 AM
ECS Tuning-Audi
A4 (B7 Platform) Discussion
09-01-2015 09:16 AM
ECS Tuning-Audi
09-01-2015 08:27 AM
