Digital A4, please explain you suspension set up. What perch did you set them at? How many finger is
your gap? Do you think they will settle in more? I am about to drop in the same setup, and want advice on how low to set them. You picture look pretty sweet, but does it look lower in person? I am thinking I might have to get race springs now, which I don't really want, but I want it to sit a little lower. Tell me what you think of yours?
okay I read your settings below. What should I set mine at, all bottom perches? Has your settled a
at all? Do you have any advice on installing these, or did you have some one do it?
Thanks
Thanks
I had it installed at a local shop.
Do you have the newer NeuBilsteins where there are more grooves in the rear? I would probablt go with the same setup I have which is 1 up from bottom on the front and all the way down on the rear. Even with these settings, the rear still sits a bit higher. With your Avant, I suspect it will even out more. And I believe it has settled a little bit. I'm not sure as to how much exactly, but visually and after constant finger gap measurements, I know it has settled a bit.
Are you using Neuspeed Sport Lowering Springs as well? If you use other springs, the drops may be different.
Good luck! Your Avant will look awesome when it's lowered with those Flik Lexs!
90quattro16
05-14-2006 05:06 PM
OWDLVR
06-07-2005 05:26 AM
s4wood
04-26-2003 12:24 PM
