does this bolt twist out or can I just beat it out? ( feels stuck )?
Old 05-27-2004, 12:01 PM
  #11
Junior Member
audiohs's Avatar
Default Yup, I had to use heat
I heated up the bolt real good and then sprayed it down with WD-40 which got sucked in. Then hammered the **** out of it and it finally came out. Unfortunately, the bolt was no good anymore and I had to replace it.
Old 05-27-2004, 12:03 PM
  #12
Head Cat Herder
Kris Hansen's Avatar
Or if you want to re-use it, leave the nut on there.. that way you don't mash the threads.
Old 05-27-2004, 12:13 PM
  #13
Member
TANMAN's Avatar
No one listens. There have been tons of posts on that. DO NOT REMOVE THAT BOLT. You don't have to.
  #14
Banned
RS41AB's Avatar
Lots of penatrant, and try turning it back and forth a bunch. It will loosen.
Old 05-27-2004, 12:16 PM
  #15
Indy's Avatar
Then how?
Old 05-27-2004, 12:17 PM
  #16
Banned
ModifiedA4's Avatar
oh no...the devil's bolt has got another victim.
Old 05-27-2004, 12:20 PM
  #17
Member
TANMAN's Avatar
Default Simply pull the bolts for the sway bar at the front of the control arms.
Have a buddy push down on teh control arm and poof. Out drops the shock assembly. Chip and I did mine in 4 hour at a slacker pace.
Old 05-27-2004, 12:21 PM
  #18
Head Cat Herder
Default Pop off the body plugs, remove the 2 nuts from the top, remove the bottom...
then push down on the brake, and lift the bottom over the lower control arm. This works on all but the 2.7t cars with the big fat CV joints.
Old 05-27-2004, 12:27 PM
  #19
Junior Member
#169's Avatar
Default DO NOT REMOVE THAT BOLT!!!!
a quick search and you will see why...I posted a while back.
BAD things can happen.
remove the shock body without touching that bolt!!!
Old 05-27-2004, 12:30 PM
  #20
Head Cat Herder
Default It's not that bad to remove it, if you do it right....
What I usually do is pop the tie rod end off the knuckle, and use my impact gun to rattle the long pinch bolt off. when I do finally get it, I use lots of anti sieze paste, and put it in backwards, to make it easier to get out the next time.
Quick Reply: does this bolt twist out or can I just beat it out? ( feels stuck )?
