E-code vertical aiming problem...
Old May 1, 2002 | 11:58 PM
SDSilver01's Avatar
Junior Member
Default E-code vertical aiming problem...
I can't aim my left headlight high enough. After maybe 50ft the light is on the ground while the right headlight is still on the wall. It sounds like the bolt is stripped at a certain point and won't go any farther.
Any suggestions??
Old May 2, 2002 | 03:12 AM
Al Pollack's Avatar
Default Yes ...
First of all, are you sure you're adjusting the correct "adjuster". For vertical adjustments, you should be adjusting the inner adjuster, for E codes. You have to be very easy, with the adjusters. The corkscrew adjusters (white plastic), can be stripped, or bottomed out, very easily.
Al
99.5 1.8tqtsc "Bullwinkle"
Old May 2, 2002 | 06:23 AM
nanotech's Avatar
Default Maybe your light is seated incorrectly?
Try loosening the bolts on top and pushing the top of the light inwards a bit, then retorquing them.
Sounds like you may have stripped the adjuster though
Old May 2, 2002 | 08:40 AM
SDSilver01's Avatar
Junior Member
Yes, I am adjusting the right screw. I think I stripped the adjuster. What can I do?
Old May 2, 2002 | 08:56 AM
J4SON's Avatar
Default What happens when you strip the adjuster?
Is the housing trashed now?
Old May 2, 2002 | 08:59 AM
SDSilver01's Avatar
Junior Member
Dang. I REALLY hope not.
Old May 2, 2002 | 10:17 AM
nanotech's Avatar
Default I doubt it
I'll try to look at mine when I get home. I'd be surprised if it was trashed, though I suppose you may have to order a replacement part for it from overseas... could be a while.
Old May 2, 2002 | 10:23 AM
SDSilver01's Avatar
Junior Member
I'm pretty sure it's stripped. How would I go about getting a replacement part?
Old May 2, 2002 | 08:53 PM
nanotech's Avatar
Default No idea... try the place where you bought your ecodes first
Does the adjustment screw have any effect at all at this point?
Old May 2, 2002 | 10:57 PM
SDSilver01's Avatar
Junior Member
Default Well, I bought them used from someone. The adjustment screw has an effect...
I can adjust it vertically still but the range of adjustment is still way too low. It seems like it is way out of wack. Below are the pictures I just took.
These pictures were taken with the car in the same position. I alternated covering the right and left headlights so you can see the beam pattern of each side.
Left headlight only (loweset setting):
<img src="http://pictureposter.audiworld.com/11354/left_headlight_low.jpg">
Left headlight only (highest setting):
<img src="http://pictureposter.audiworld.com/11354/left_headlight_high.jpg">
Right headlight only:
<img src="http://pictureposter.audiworld.com/11354/right_headlight.jpg">
Both headlights:
<img src="http://pictureposter.audiworld.com/11354/both_headlights.jpg">
As you can see, the left headlight at its highest setting is way below the right headlight.
