ECU Soft code - Emissions Type codes?
Old Oct 5, 2004 | 02:59 PM
Uber Wagon 2.0's Avatar
New Member
Default ECU Soft code - Emissions Type codes?
So,
I wrote down the softcode on my ecu not really knowing what all of the numbers mean.
"07251"
Does anyone know what the codes for digit #2 (Emmissions Type) are?
I fond the description below on anoter board, and it says "06xxx" is the designation for USA. Mine is "07"? Anyone know the difference? Anyone else have a 7?
I'm just curious more than anything.....
Thanks.
Here's what I found explaining the others.
1st digit is country code,
2nd digit is emissions type,
3rd is drivetrains option,
4th is transmission type,
5th is vehicle type.
06 - (USA)
0 - FWD w/o ASP,
1 - FWD w ASP,
2 - AWD w/o ASP,
3 - AWD w ASP
0 - 5speed manual,
5 - autotrans
1 - A4
Old Oct 5, 2004 | 06:13 PM
Nate (ETKA+Scumbag)'s Avatar
Keeper of the Cash
Tech Guru
Default I shot you an email with the coding graph from my service manual. No thanks is needed, just helping
out a fellow Audi driver. I like your Über name too, lol. My code for my '97 1.8T with Quattro (USA) is 06251 if that helps any.
Old Oct 5, 2004 | 10:55 PM
New Member
Default Got it.....
Thanks.
Now I'm really curious why mine has a 07 instead of 06????
Old Oct 6, 2004 | 01:15 AM
ModifiedA4's Avatar
Banned
Default i noticed the same difference...my bentley states 06 is correct.
<center><img src="http://www.modifieda4.com/images/technical-docs/A4_ECUcoding.gif"></center><p>
i believe the 06/07 difference is engine type/year dependent.
Old Oct 6, 2004 | 09:12 AM
Keeper of the Cash
Tech Guru
Default I really don't know either. I really haven't worked with new(er) Audis...
so maybe its a new country code. At any rate, if the WSC (Work Shop Code) is 06335, that means it was programmed like that at the Audi assembly plant, and should probably be left alone. You might want to consider talking with an Audi dealer tech to find out if there is a good reason as to why its country code is 7 and not 6. If/when you do find out, shoot me an email or post it so I can take note as well.
Sallad
Jun 4, 2019 08:18 AM
Tendai Kufandirori
A4 (B8 Platform) Discussion
Apr 29, 2019 10:31 AM
96Audimobile
Nov 21, 2006 04:20 PM
ray_tx
Feb 14, 2005 12:06 PM
ivansis
Aug 23, 2001 03:27 PM
