electrical help needed!
1. You need to replace the 12V distributer unit located just underneath the fuse box. One rusted unit can cause quirks throughout the engine.
2. Splice the green AC wire running fron the fuse to the air conditioning wire with the blue AC wire, and then split the resulting line. This should take out the power source confusion between the two units.
3. Detatch the left headlight unit, or whichever unit is closest to the fuse box in order to give yourself more access to wires running along the front fender. You're going to need to check those to make sure there are no splits in the line.
4. Ignore all this I have no clue what I'm talking about.
I hope this helps
