Electrical issue killed starter and all windows?
Old 04-29-2017, 07:17 AM
john_quinn124's Avatar
Default Electrical issue killed starter and all windows?
I just recently pulled out my central locking pump and am getting a new one. My car decided not to start at all yesterday so i pop started it and it ran fine but all the windows wouldnt go down. Is there some common electrical issue that causes this or is the central locking pump related to the power windows. I assume the starter is completely unrelated to the locks but i would appreciate any help. Thanks!
Old 04-29-2017, 06:52 PM
David.Norton's Avatar
The locking module also works the windows, so pulling it could disable the windows (I don't know for sure, but seems likely).
Old 04-30-2017, 07:07 AM
Thanks... that makes it a lot simpler i suppose. The started must have just died out of nowhere.
Old 04-30-2017, 07:12 AM
Another issue is i dont know if the key retracts from start on b5's because mine never did and maybe that could be the issue.
Old 05-01-2017, 05:03 AM
If the key is not moving back from start the switch is likely bad. It does have an internal spring.
Old 05-01-2017, 02:13 PM
Would i need a new key as well or is it seperate from the key hole and could this have killed the starter?
Old 05-01-2017, 03:39 PM
The electrical part is separate from the lock, it mounts on the back. And yes, a bad switch could keep the car from cranking. I would note that there are other issues that could keep it from cranking, however if your switch is not returning from start chances are good you need at least the switch, and you might be lucky and have that be the end of the problem.
Old 05-01-2017, 07:44 PM
Thanks for the advice!
bagxlee
12-07-2009 05:19 AM
bugbear
04-21-2007 11:11 AM
bugbear
01-24-2007 04:14 AM
Waskly1977
Audi Original "S" Cars
09-21-2006 03:30 PM
Erix
Audi 100 / A6 (C4 Platform)
08-02-2005 05:29 PM
Quick Reply: Electrical issue killed starter and all windows?
