Electrical issues
Old Jan 25, 2017 | 10:40 PM
Karrel's Avatar
Default Electrical issues
Hi,i got a Audi B5 2.4L and these are the issues that i am experiencing; the battery light (dim) flickers in the dashboard, the voltage drops in between 12&14 volts when i switch on the fog lights,wipers and heater at the same time and before when i remove the ignition key the headlights could go off automatically but now they don't anymore and if the heater was on the fan will keep on spinning although the climate control is off until i manually switch off the lights then everything will go off and i bought a new battery and i noticed that it leaks whenever i use all these components, now my question is;is it a bad ground connection or a bad voltage regulator? anybody help please
Old Jan 26, 2017 | 05:19 AM
David.Norton's Avatar
Could be bad connections, but it sounds like the alternator. These cars are at the age where the brushes are going to be wearing out, and the bearings are likely not far behind. So I'd get the voltmeter out and check between the engine and battery ground, and if it checks out (low drop) I'd pull the alternator and rebuild it.
Old Feb 1, 2017 | 03:51 AM
Karrel's Avatar
Ok i ll try that too, because it ry replacing the brushes but still doing that.thanks
joncowden
Sep 1, 2009 05:06 AM
zoomob
Aug 9, 2004 09:25 PM
ProvGirl22
Audi 100 / A6 (C4 Platform)
Mar 21, 2003 06:20 AM
JPCady
12
Aug 23, 2002 11:57 AM
slook
Oct 27, 2001 02:56 PM
