Electronic Stabilization Program (ESP) ??? what is this?
Old Aug 28, 2000 | 02:04 PM
a4miille's Avatar
New Member
Default Electronic Stabilization Program (ESP) ??? what is this?
What in the world is this?
Old Aug 28, 2000 | 02:21 PM
Jason H's Avatar
Default A computer controlled system that basically gives the car four brake pedals in a sense...
allowing the car to detect unusual yaw movement and selectively apply braking to only the wheels needed to bring the car back into line. This is done automatically without driver input and can be felt like a giant hand readjusting your drive line when you overcook a corner.
Old Aug 28, 2000 | 02:30 PM
a4miille's Avatar
New Member
Default is it worth it? do you have it?
i am going to get a a4 1.8t qma. is it something i should look in to ?
Old Aug 28, 2000 | 02:33 PM
a4miille's Avatar
New Member
Default Re: A computer controlled system that basically gives the car four brake pedals in a sense...
or does it prevent body roll?
Old Aug 28, 2000 | 02:34 PM
Jason H's Avatar
Default No, I have a 2000 before it was availible...
If I were ordering my car again, it would be a toss-up as to whether to get it. With Quattro and EDL alone, the car feels incredibly stable, even on wet, mudslicked roads. I also like that the car will do exactly what I want it to and not make descisions for itself! That said it is nice to have a back-up if you f- it up beyond your skill level. One use could pay for the investment. You can always turn it off when not needed, but this leaves a constant warning light lit in the display, kinda annoying.
Old Aug 28, 2000 | 02:40 PM
Jason H's Avatar
Default no, just yaw rate. You're describing Active Body Control...
which is used in some VERY expensive cars. It basically takes ESP and adds active body control (spring rates, damping, cars attitude) That is the height of computer controls (without the car steering itself!) the hierarchy of electronic stability is:
1. ABS
2. ASR (two wheel drive anti-slip detection)
3. EDL (electronic differential lock, moves power side to side)
4. ESP
5. ABC (active body control)
Old Aug 28, 2000 | 03:13 PM
LCP's Avatar
LCP
AudiWorld Expert
Default ESP will also cut the power on you if it kicks in...
Nick Snyder's got it on his new S4 and hates it. It is very intrusive. I think if it detects any wheelspin whatsoever it tries to save you (even simple turns where you're just accelerating through the corner). On snow or ice maybe it'd help.<p><img src="http://pictureposter.audiworld.com/AudiWorldPics/2000/LCPawsig1.jpg">
- Lance (corporate lawyer type turned track time junkie)
"I can't stop apexing"
Old Aug 28, 2000 | 04:18 PM
tonypilot's Avatar
Default ESP Info.
<p>cessna_Joe<ul><li><a href="http://www.vwvortex.com/news/02_00/02_11_00/index.html">http://www.vwvortex.com/news/02_00/02_11_00/index.html</a</li></ul>
Old Aug 29, 2000 | 07:21 AM
DavidT's Avatar
New Member
Default Re: is it worth it? do you have it?
Yes, it's worth it, and yes, I have it. It's a sensible safety option one will appreciate when rounding corners a little too quickly
bluebird
26
Jun 15, 2019 06:41 PM
Vijay
RS4 (B7 Platform) Discussion
14
Feb 26, 2007 10:50 AM
Harbor A6
12
Dec 28, 2003 02:19 PM
SlehStar
Jul 23, 2002 05:37 AM
BoyTToy
9
Mar 30, 2001 09:43 PM
