engine code
Old Mar 8, 2011 | 10:11 AM
a4 taz's Avatar
Default engine code
p1300 and p1237 does anybody know wat that means
Old Mar 8, 2011 | 10:33 AM
4Driver4's Avatar
Tech Guru
Tech Guru
It means you are using a universal scanner. Google is your friend.
Old Mar 8, 2011 | 11:25 AM
a4 taz's Avatar
its a misfire and fuel air but i chaned coils and plugs 8 months ago.\
its probably because of the valve gasket
Old Mar 8, 2011 | 11:55 AM
4Driver4's Avatar
Tech Guru
Tech Guru
1237 is related to an Cylinder one injector. Is it plugged in correctly? Working?
1300 is a low fuel misfire. Run out of gas recently?
I don't see how either could be related to a valve cover gasket.
Old Mar 9, 2011 | 06:06 AM
a4 taz's Avatar
ive been low but not run out. but do u think if i change the injectors it would be back to normal. it runs but very sluggish and the misfire takes bout alot of power to drive
Old Mar 9, 2011 | 06:27 AM
xsrfsno225x's Avatar
honestly I think you should someone with a vagcom
Old Mar 9, 2011 | 06:38 AM
4Driver4's Avatar
Tech Guru
Tech Guru
I'd swap injectors one and two, clear codes, drive car and see what comes back.
Old Mar 9, 2011 | 01:53 PM
a4 taz's Avatar
its saying cylinder one misfire
Old Mar 9, 2011 | 03:00 PM
a4 taz's Avatar
how do i find out which cylinder is which?
Old Mar 9, 2011 | 05:18 PM
4Driver4's Avatar
Tech Guru
Tech Guru
C'mon, dude, do a little bit of homework. Does anyone look in the tech section?
Cylinder one is at the front. Assuming your previous post is directed to me (it is threaded back to one of your posts), I should clarify: swap injector one and two *with each other* and try again. If the misfire moves, the injector (was one, now two) is bad and needs to be replaced. If it doesn't move and you get the one code again, the injector is not the problem.
Does that make more sense?
