engine overheating
Old May 15, 2007 | 10:19 PM
powell river's Avatar
New Member
Default engine overheating
Hi all, i have a 97 1.8t quattro automatic. I chipped it last week with an APR chip and now loving the extra power. However, after driving it for a while i can see that my coolant temp gauge and oil gauge in the car are both going up to about 110c. Any suggestions of what i need to do? i am lost since i am not knowledgeable mechanically. Thanks
Old May 15, 2007 | 10:38 PM
JAFO's Avatar
Default turn on the ac and see if the electric radiator fan is running......
how long since you changed the coolant?
Old May 16, 2007 | 07:51 AM
New Member
Default Re: turn on the ac and see if the electric radiator fan is running......
come to think of it i haven't change the coolant since two summers ago. I'll try and see about the electric radiator fan thing. Thanks for your reply
Old May 16, 2007 | 09:56 AM
JAFO's Avatar
Default when did you do the timing belt?....
wisdom here is 4yrs or 60K mi. if you're close or over that it's time. the other common problem which causes over heating is a failed water pump, the impeller separates from the shaft. you can buy a timing belt kit from several vendors here, i got my last one from purems.com. the kit includes the front part of the water pump and a thermostat as well as all the acc. belts.
Old May 17, 2007 | 07:57 AM
New Member
Default Re: when did you do the timing belt?....
my electric radiator fan is running fine. I'm gonna go and get a coolant flush and see if that fix the overheating problem. If not then i'll get the timing belt thing done. Thank you for being so helpful
Old May 17, 2007 | 09:16 AM
JAFO's Avatar
Default good luck.....
if you do the timing belt you should do the valve cover gasket and the cam end seals at the same time as it's easiest with the tb off. this will also let you check the cam galleries for signs of sludge. you should read the faq if you intend to keep the car for any lenth of time. the tech section also has allot of useful info.<ul><li><a href="https://forums.audiworld.com/a4/msgs/2299748.phtml">https://forums.audiworld.com/a4/msgs/2299748.phtml</a</li></ul>
kyleb
Jan 12, 2016 06:14 PM
mad scientist
Mar 2, 2008 05:06 AM
Mark.core
12
Aug 9, 2006 01:42 PM
fredfromny
11
Aug 31, 2004 02:31 PM
DrRings
Jul 1, 2003 06:32 PM
