Engine running rough
Old May 8, 2010 | 06:53 AM
Zigra's Avatar
Default Engine running rough
Over the past month or so my 2001 1.8t will run rough when there is heavy boost.
My CEL light has only been on only once when I kept on the gas pedal and it only flashed twice and never has been on since.
I have read some of the threads on the threads on the boards.
Was wondering if anyone could help me out a bit.
I have been to a very recommend shop many times and yet it still has not been fixed.
I have gotten the new recalled Coil packs from Audi and it still does it.
My car has been flashed, Had the speed sensor changed not to long ago.
I have 139k miles on it
I have a high flow cat with down pipe. (need to get it replaced)
I have had my throttle body cleaned out about 30k miles ago
Have not changed my spark plugs in about 50k miles
Other then that my car is stock
any help would be great.
Old May 8, 2010 | 09:35 AM
AudiMick's Avatar
If you knew what the code was we could probably help. Code readers are cheap, even a generic VAG.com from E-bay might help. The $50 code readers from Harbor Freight can work well also,
Why do you have a high flow cat? Is your car chipped? 50K is a lot for plugs on a chipped car.If your car is chipped do you still have a stock DV.
Old May 8, 2010 | 10:33 AM
Zigra's Avatar
I don't have a scanner guessing it would be a good investment.
yes the car is chipped. i am in Florida want to keep it legal if i ever want to sell it.
And yes i still have a stock diverter valve
Old May 8, 2010 | 04:35 PM
AudiMick's Avatar
With a chipped car you should invest in a VAG.com. I wouldn't change anything until I had scanned the car.
Many people with chipped cars run copper plugs and often change them every 5000 miles, make sure you are running the correct gap for a chipped car. The stock DV is often overwhelmed by the increased boost, an OEM TT DV valve (710N) is a common replacement as it can handle the higher boost.Not too expensive either.
Old May 9, 2010 | 07:17 AM
Zigra's Avatar
Okay
Thank for the info.
i will need to order a vag soon then
Peter VIP
A6 (C7 Platform) Discussion
Aug 3, 2018 03:22 PM
iSynthetixx
Jun 24, 2015 04:18 PM
shakedown71
Dec 14, 2009 12:31 PM
LynxZ3r0
Dec 8, 2005 09:07 AM
jprice@CPS
Nov 29, 2002 08:12 PM
